How Much Electric Does a Mini Fridge Use: Simple Calculation
Mini fridges are handy little appliances—whether you’re using one in your bedroom, home office, campervan, or during weekend getaways. They’re perfect for keeping drinks cold, snacks fresh, or powering your road trip kitchen setup. But how much electric does a mini fridge use?
Whether it’s plugged in all day at home or hooked up to a leisure battery on the road, knowing its power consumption can help you avoid nasty surprises—on your bill or your battery. In this guide, you’ll learn how much energy mini fridges use, how to calculate it, and smart ways to reduce that usage—whether you’re at home or off-grid.
How Much Electricity Does a Mini Fridge Use per Day?
Mini fridges don’t need much power to run, whether they’re sitting under your desk or tucked inside a campervan. Most typical plug-in models only use about 50 to 100 watts while the compressor is running.To put that in perspective, when you ask, how many watts does a refrigerator draw, a regular home refrigerator usually uses anywhere from 350 to 800 watts.
Now, when it comes to daily energy usage, here’s something important: even though the fridge is plugged in all day, it doesn’t run non-stop. On average, the compressor kicks on for around 8 hours out of every 24, depending on the room temperature and how often you open the door.
So, for example, if you’ve got a 4-cubic-foot dorm-size fridge rated at 100 watts, its daily energy use would be:
100W × 8 hours ÷ 1000 = 0.8 kWh per day.
Here’s a quick look at how much power standard 230V mini fridges tend to use on average:
Rated Fridge Wattage
Daily Usage
Monthly
Yearly
50W (small cooler)
0.40 kWh
12.2 kWh
146 kWh
65W (hotel mini-bar)
0.52 kWh
15.8 kWh
190 kWh
80W (3 cu ft fridge)
0.64 kWh
19.5 kWh
234 kWh
100W (larger compact)
0.80 kWh
24.3 kWh
292 kWh
These figures assume a typical ⅓ duty-cycle (≈8 hours/day compressor runtime).
In fact, many UK energy-labelled “table-top” models now sit around 150 kWh per year, thanks to stricter EU/UK eco-design rules.
Camping compressor fridges, which run on 12V car power, are even more efficient. Designed for off-grid use, these fridges usually pull between 1 and 4 amps (≈12–48W) and cycle on and off throughout the day. In moderate temperatures, they might only draw 25–40 amp-hours (Ah) over 24 hours—perfectly manageable with a leisure battery and some solar support.
Their off-grid power use will typically look like this:
Fridge Type
Estimated Daily Draw
Energy Use
Battery Needed
Small (25 L)
25 Ah
300 Wh
100 Ah battery: 3+ days
Medium (40–45 L)
30–35 Ah
360–420 Wh
100 Ah battery: 2–3 days
Large (60 L+)
35–40 Ah
420–480 Wh
100 Ah battery: 2 days or less
How to Calculate Power Consumption of a Mini Fridge?
Trying to reduce your home electricity bill or want to know how long your fridge can run off a battery while camping? Calculating power use is simple, here’s how:
1. Find the power rating
Look for a label or manual that lists the wattage (W) or current draw (A). For camping fridges, this is often given in amps.
2. Estimate daily runtime
Most compressor fridges run for 6–10 hours per day depending on conditions. Use 8 hours as a good middle ground unless you’re in a hot environment.
3. Use the formula
For mains (230 V): Daily kWh = (Watts × Hours) ÷ 1000
For 12 V setups: Ah = Amps × Hours, then Wh = Ah × 12V
4. Scale it up
Want to know how much electricity does a mini fridge uses per month? Just multiply daily use by 30.4 for a monthly estimate, or by 365 for the yearly figure.
5. Estimate cost or energy demand
At home: multiply kWh by your electricity tariff (e.g. £0.24/kWh).
While camping: compare Wh to your battery size and solar output.
Example
Now, let’s look at some examples:
Mains Mini Fridge (230V)
Let’s say you have a 65-watt mini fridge that runs for about 8 hours a day.
Here’s the breakdown:
65W × 8 hours ÷ 1000 = 0.52 kWh per day
Over a year, that adds up to:
0.52 kWh × 365 days = 190 kWh annually
If electricity costs £0.24 per kWh, that’s:
190 × £0.24 = £45.60 per year
Camping Fridge (12V)
Now take a camping fridge that runs on 12V and draws 3 amps when it’s running. If it runs for 8 hours a day:
3A × 8 hours = 24 Ah per day
Multiply that by 12V and you get:
24 Ah × 12V = 288 Wh per day
If you’re using a 100Ah lithium battery (with about 80Ah usable capacity), it could power the fridge for roughly 3 days without needing to recharge via solar or other means.
Factors Influencing a Mini Fridge Electricity Usage
As discussed, the answer to “How much electricity does a mini fridge use?” can depend on a range of factors, from its size and model to where you put it and how you use it. Let’s break them down:
Ambient Temperature
Heat is the biggest factor. The warmer the surrounding air, the harder your fridge has to work. In fact, tests show that a camping compressor fridge can cycle three times more often at 43°C than it does at a more comfortable 21°C. Indoors, placing your fridge next to a cooker, radiator, or even in direct sun can push energy use way up.
Ventilation and Airflow
Fridges need space to breathe. If the heat from the condenser coils can’t escape properly—say, because the unit is boxed into a cabinet or pushed against a wall—it has to work harder to stay cool. Even just blocking the airflow by a few centimetres can increase power draw by over 10%.
Size, Age, and Efficiency
Larger 60 L+ fridges use more energy simply because there’s more space to cool. Older fridges—especially those over five years old—can also draw significantly more power as their compressors wear down and insulation degrades.
How Often the Door’s Opened
Every time you open the fridge door, cold air escapes and warm, humid air gets in. That extra heat and moisture mean the compressor has to switch back on sooner and stay on longer. The more often the door is opened, the more energy the fridge uses.
Worn or Damaged Door Seals
If the door gasket doesn’t seal properly, your fridge leaks cold air all day long—even when the door is closed. That can cause a constant cycle of energy loss, making your compressor run more often and shortening the fridge’s lifespan in the long run.
Frost Build-Up and Defrost Cycles
More than 5 mm of frost on the evaporator can reduce cooling efficiency by insulating the surface and slowing heat exchange. On top of that, fridges with automatic defrost heaters can add another 5–10% to your overall energy use just by running their internal heaters.
Thermostat Settings
Setting your fridge lower than necessary doesn’t just chill your snacks—it also bumps up your power consumption. Every degree below around 3 °C increases energy use by roughly 5%.
Tips to Reduce Energy Consumption with Your Mini Fridge
Mini fridges might be smaller than regular refrigerators, but they still use electricity every day, and over time, it adds up. When you cut down on energy usage, it helps save some money along the way. Here are smart, simple tips to reduce your mini fridge’s energy consumption.
Give It Room to Breathe
Make sure your fridge has at least 5 cm of space around it—especially at the back and sides. Good airflow around the vents and coils helps it run more efficiently.
Keep It Out of the Heat
Don’t place your fridge next to ovens, radiators, or in direct sunlight. For camping setups, shade the unit or use insulation to stop it heating up unnecessarily.
Choose a Sensible Temperature
For most uses, 3–5°C is ideal. Going colder than that rarely benefits food safety and only adds to your power bill.
Limit Door Openings
Try to avoid leaving the door open longer than needed. Know what you want before you open it, and close it promptly to reduce cold-air loss.
Maintain the Door Seal
Wipe down the gasket regularly to keep it clean and flexible. If it doesn’t hold a slip of paper when closed, it might be time to replace it.
Defrost Regularly
Ice build-up reduces efficiency. Once the frost hits 5 mm thick, it’s time to defrost—especially if your fridge doesn’t do it automatically.
Don’t Overpack
A fridge works best when it’s about two-thirds full. This keeps the cold air stable without blocking airflow around the interior.
Use Eco Mode
Many 12V models have an energy-saving setting that lowers compressor speed and reduces average power draw—especially useful overnight.
Choose or Upgrade to an Efficient Model
One of the best ways to cut down on energy use is to start with the right fridge. Look for an A-rated model, which sits at the top of the UK and EU energy label scale. It’s a quick way to compare efficiency at a glance.
From there, check the spec sheet for low rated wattage, thick insulation, and an Eco mode—all signs of a fridge that keeps contents cold without constantly draining power.
A great example is the EcoFlow GLACIER Classic Portable Fridge Freezer. It runs on a highly efficient compressor that draws just 55 watts when plugged into mains. Unlike traditional models, this mini fridge offers a dual-zone design in the 45L and 55L versions, letting you store both fresh and frozen foods at once without using extra energy.
Thanks to its built-in 298 Wh battery, it can stay cold for up to 43 hours without needing a charge. But when it does, it recharges via solar (up to 240W), a standard wall socket, or your vehicle.
With thick insulation to hold steady temperatures, it reduces how often the compressor needs to kick in, making it ideal for off-grid setups. Choosing something this efficient means fewer worries about flat batteries and more time enjoying the trip.
The EcoFlow GLACIER Classic is a portable fridge and freezer available in 35L, 45L, and 55L sizes. It uses a high-efficiency copper wire compressor to cool quickly and consumes less power. The unit can store up to 58, 72, or 90 cans, depending on the model. A 298 Wh plug-in battery can power the fridge for up to 43 hours at 4°C in the 35L model and 39 hours in the 45L and 55L models. The fridge also supports AC, car, and solar charging. The temperature, power settings, and alerts can be controlled through a mobile app.
Whether you’re keeping a few beers cold at home or running a fridge from a van battery in the Highlands, understanding how much electric a mini fridge uses can save you money—and headaches. As we’ve learned, a standard mini fridge plugged in at home can use anywhere from 0.4 to 0.8 kWh per day, or 150 to 300 kWh per year. Modern 12V camping fridges use even less. By setting the right temperature, closing the door quickly, or upgrading to a more efficient model, you can get the most out of your mini fridge—without overloading your battery or your budget.
How much does it cost to run a mini fridge?
A typical mini fridge in the UK uses around 50–150 kWh per year, depending on its efficiency and size. With the current electricity price of ~29p per kWh, that works out to approximately £14.50–£43.50 annually.
On a per-day basis, that’s roughly 4–12p each day. Of course, newer, more energy-efficient A-rated models can be even cheaper to run—some might cost you as little as £20–£30 per year. To get an exact figure, check your model’s annual kWh rating and multiply it by your per‑kWh rate.
Is a mini fridge expensive to run?
Not really! Mini fridges are among the cheapest appliances to maintain. At ~£15–£45 per year, they’re far less costly than larger fridges or freezers. Even if you add one alongside your main fridge—for chilling drinks in a bedroom or office—it would only add a few pence per day.
Energy efficiency ratings matter too—choosing an A‑rated or A++ model can reduce running costs by £10–£20 a year compared to older units. Bottom line: a mini fridge is budget‑friendly, and with smart use (like keeping it away from heat and not leaving the door open), it’s very affordable to run.
Saving Bills
